Third party software and hardware support forums. > LazyTurn
Lazy Turn way of life?
rockyrude:
I am using Lazy Turn as I much prefer the results over Lazy Cam, I have noticed the finish tool path generator inserts an extra line number in the gcode approximately every 5600 lines (yes, it's a big part). It's not a big deal to edit them out, is this normal?
RICH:
You should just scroll through the generated code in Lazyturn as there are a few ( 1 or 2 things ) codes that get posted that should be fixed.
LT is the way it is and will not get updated.
zarzul:
I noticed this also, it seems that mine does it every time it generates a G0.
I just do a "Find" "G0" in my text editor and delete the extra line number.
gojo:
Hi All,
Not sure if you can help me but I've set my lathe up with a high torque stepper to try some simple threading. I've calibrated the spindle and can control it with mach3. I don't have my tach yet and I'd like to lock the spindle speed to the STrue value. Anyone know a quick way to do that?
Gordon
RICH:
Gordon,
Am I correct in saying that you are using a stepper motor to drive a conventional lathe spindle?
Navigation
[0] Message Index
[#] Next page
Go to full version
