Hello Guest it is November 01, 2026, 10:06:14 AM
Author Topic: Lazy Cam?  (Read 39432 times)
Re: Lazy Cam?
« Reply #10 on: May 01, 2006, 03:25:08 PM »
Cool that will help me find the problem!
Brian
www.newfangledsolutions.com
www.machsupport.com
Re: Lazy Cam?
« Reply #11 on: May 06, 2006, 05:45:41 PM »
I found the problem and I am fixing it now... it will be in the new release.
www.machsupport.com
Re: Lazy Cam?
« Reply #12 on: May 06, 2006, 06:00:02 PM »
Thanks Brian  ;)
Jean-Louis
Re: Lazy Cam?
« Reply #13 on: May 10, 2006, 03:51:57 PM »
Hi Brian,
Thanks for the version 2.0 of LC. I'm very impressed by your reactivity !
So I've tested the new release of LC with the same dxf file.
Everything works fine for the inside chains but for the outside chain, it has generated a G42 code instead of G41.
Sorry to give you some more work  ;D
Jean-Louis
Jean-Louis
Re: Lazy Cam?
« Reply #14 on: May 10, 2006, 04:09:42 PM »
No problem I will have to look at the code again... I used another test file and I must have missed something! I will see if I can find it.
Brian
www.machsupport.com
Re: Lazy Cam?
« Reply #15 on: May 14, 2006, 04:22:37 PM »
Hi Brian,
I discovered something else regarding this problem that may help you to fix it.
If I set tool 1 (for instance) for both layers (inside and outside) in the layer control, a G42 is generated for the outside chain (as explained previously), but if I set tool 1 for inside layer and tool 2 for outside layer, then the code is properly generated, with G41 for both inside and outside chains.
Hope it helps.
Jean-Louis
Jean-Louis
Re: Lazy Cam?
« Reply #16 on: May 14, 2006, 07:09:48 PM »
That is a big help in finding the problem! Thank you!
www.machsupport.com
catheic
Re: Lazy Cam?
« Reply #17 on: May 18, 2006, 12:18:38 AM »
ok i think i know now what to do  :-\ ::).. first is to download the latest version and test again. wow! we always have new updated version from time to time.. which is good.
we users just have to check if our versions are up to date. ;)
more power to you all!
« Last Edit: May 18, 2006, 12:38:42 AM by catheic »
Re: Lazy Cam?
« Reply #18 on: May 18, 2006, 06:17:23 AM »
I a sorry about that... Lcam is going to be a good program but you all  are helping us get the bugs out  :o So in time you will see it get better and better. I will be working on Lcam for the next few weeks after I get back from the workshop. Thank you and hang in there we will have something that you like in the end!
www.machsupport.com
