Hello Guest it is October 22, 2026, 07:42:06 PM
Author Topic: Help with tool change in mach3 turn.  (Read 14016 times)
Offline RFord
  •  7 7
  • Who is guarding the guards?
    • Rick's Woodworks
« on: June 17, 2007, 08:52:47 PM »
Hi All
I am looking for help getting the tool change to work on my lathe.  I have a tool turret but it has to be programmed to a linear position to make it rotate.. ( Won't use degrees)  I can make it rotate to a specified position but I can't get the tool offsets to work.  Here is a code I wrote to position the tool tip at a specified point.
 ( THIS PART sets up tool 1 and tool 3)
G0 x3 z6
G0 A0 (rotate tool turret to pos 1)
T1 (Load tool 1)
G43 H1  (load tool 1 offsets all set to 0)
G0 x2 z0 (Touch corner of setup stock)
G0 x3 z4 ( Move Away from stock)
G0 A-7.2 (Rotate tool turret to tool 3)
T3 (Change to tool 3)
G43 H3 (Load tool 3 offsets)
G0 x2 z0  (Touch corner of tool to setup stock)
M3
Screen shots of the tool table and the tool setup screens are attached.
Rick
Offline MarkC
  •  94 94
Re: Help with tool change in mach3 turn.
« Reply #1 on: June 17, 2007, 09:32:48 PM »
Instead of using: T1
G43 T1
try this:
T0101
this will use T1 offset#1
Mark
Mark
Offline RFord
  •  7 7
    • Rick's Woodworks
« Reply #2 on: June 18, 2007, 01:00:05 PM »
 ;D Thanks Mark,
 That worked after some trial and error.
Rick
