Hello Guest it is November 11, 2026, 11:15:21 AM
Author Topic: Font Islands  (Read 9340 times)
Font Islands
« on: March 11, 2017, 12:52:57 PM »
Is there an easy way to leave fonts as islands, similar to making a number plate as found on steam Locomotives?
Roger
Offline kolias
  •  1,165 1,165
Re: Font Islands
« Reply #1 on: March 11, 2017, 04:47:12 PM »
Not sure what you mean but perhaps you are talking about relief machining as per attached copy I found on the web. In your CAM software you should be able to select the areas around the letters and create "pockets" so you letters can stand out like "Islands"
Nicolas
Re: Font Islands
« Reply #2 on: March 13, 2017, 05:18:43 AM »
Thanks for your reply, yes that is what I had in mind.
I had hoped that there may be a way of doing it  other than Using Cam.
Looks as though I will have to go that route.
Thanks again
Roger
  •  9,377 9,377
Re: Font Islands
« Reply #3 on: March 13, 2017, 05:32:47 AM »
Check out F-Engrave. It is free and the video on inlay describes the type of engraving you are describing http://www.scorchworks.com/Fengrave/fengrave.html
