Hello Guest it is October 22, 2026, 08:39:50 PM
Author Topic: problem with my tool lenght sensor  (Read 8594 times)
Offline beat
  •  15 15
« on: March 05, 2017, 10:39:56 AM »
hi all
i need your help  :o
i try to use a tool length sensor with mach 4 but i don`t unterstand how i can use the measurement.
what i`ve done:
i use a Ethernet smoot stepper plugin.
and i`ve already configured my input as a probe.
if i press the button on my tool length probe, the probe light in the machine diagnostic is going on.
so i think the configuration is ok.
if i press a button (for example) z position "measure z" something like a macro is executing but few seconds later nothing happen and the enable switch is flashing green. my cnc machine is doing nothing.
is somebody here who can help me with the settings, should i configure something more? not just the input from the tool length sensor?
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: problem with my tool lenght sensor
« Reply #1 on: March 05, 2017, 01:14:10 PM »
What version of the ESS plugin are you using?? If its v194 then go back to v193 as probing is not functional in v194.
DazTheGas
Offline beat
  •  15 15
« Reply #2 on: March 05, 2017, 01:31:39 PM »
Oh really?
Ok, i check this tomorrow evening.
Thank you for your answer.
Beat
Offline beat
  •  15 15
« Reply #3 on: March 06, 2017, 02:24:56 PM »
Hi Daz the Gaz
I've version 186
Do you know, is this version ok?
And could you tell me how i can measure my tool length?
Maybe i make something wrong  :-\
Thank you for your help
Beat
Offline beat
  •  15 15
« Reply #4 on: March 12, 2017, 04:09:10 PM »
Hi all
Is somebody here who can tell me how the probing  should working?
Thank you for your help.
Kind regards
Beat
