Hello
Guest
it is
October 28, 2026, 07:40:02 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
machine is out by .5mm in x and y axis even after setup
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: machine is out by .5mm in x and y axis even after setup (Read 20191 times)
meady638
3
Re: machine is out by .5mm in x and y axis even after setup
Reply #10 on:
March 02, 2017, 04:34:29 PM »
Tried what you said and i can repeat it accurately for movement to 1000mm but when machining again its out by .3mm. This is strange.
Logged
matthew86
10
Reply #11 on:
March 03, 2017, 03:41:33 AM »
may I kindly ask anyone to write a simple code for a square that measures 50mm x 50mm at 2mm deep with a 6mm endmill, zeroed bottom left corner. may be worth seeing if its a coding error from Artcam when being created
Logged
Tweakie.CNC
9,375
Super Kitty
Reply #12 on:
March 03, 2017, 04:11:43 AM »
Try this.
Logged
matthew86
10
Reply #13 on:
March 03, 2017, 04:12:44 AM »
thank you sir, will try it later today after work. much appreciated
Logged
Print
Pages:
1
2
Go Up
« previous
next »
