Hello Guest it is November 22, 2026, 04:04:46 PM
Author Topic: techno isel refit  (Read 11991 times)
techno isel refit
« on: June 13, 2007, 02:07:19 PM »
Hi I have a techno servo router with a dos based controle.
The machine it self an the elctronics work fine.
The controler also works but its a pain.
Does anybody hear have any experience converting one of these to run with mach3 or an older version.
I was hoping to be able to somehow interface with the aktual box rather then having to build a new one with gecko drives ore something like that.
at the moment I just want to no if anybody here has already done so or at least thought about it.
KAI
Re: techno isel refit
« Reply #1 on: June 14, 2007, 08:33:55 PM »
You will need to put up pictures and more info about the servo drives the machine has.
« Reply #2 on: July 16, 2007, 09:05:16 PM »
I converted my Techno control to work of Mach3.  When I purchased my machine it did not come with any Techno control software or pc boards.  I established which wires controlled the step and direction for the motors and setup Mach3 to use the existing Techno controls and drives.  Recently I upgraded my system to Servo motors and Gecko 320  drives.  I will post some pictures in the future of my setup.
