Hello Guest it is October 22, 2026, 08:43:24 PM
Author Topic: Mach4 cutting feed rate on a 450,000 line gcode?  (Read 23986 times)
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Mach4 cutting feed rate on a 450,000 line gcode?
« Reply #10 on: January 31, 2017, 12:00:27 PM »
Have you thought of running the gcode without the toolpath as a test.
DazTheGas
Offline HoY
  •  18 18
« Reply #11 on: January 31, 2017, 12:49:44 PM »
I'll try that if I get another order for a calendar.
Offline HoY
  •  18 18
« Reply #12 on: February 01, 2017, 11:08:31 AM »
here I am, ready to try it, but dont remember where I saw the option to run the tap without the toolpath showing. anyone able to remind me?
Offline DazTheGas
  •  778 778
  • DazTheGas
Offline HoY
  •  18 18
« Reply #14 on: February 01, 2017, 12:27:55 PM »
thank you!
Offline Pedio
  •  200 200
« Reply #15 on: February 01, 2017, 08:02:15 PM »
Hoy and Pedio, do your PCs specs meet the minimum requirements (particularly the graphics card)? If not, expect such issues with large Gcode files. Note: There is no limit for GPU RAM but the larger the Gcdoe files, the more you need.
Also, why use a laptop? Not that you can't, but since the PC controlling Mach should be a dedicated PC (with no apps loaded non-essential to Mach particularly antivirus) I have never been able to come up with a reason to use a laptop.
I have a HP desktop that is dedicated to running the machine. What are the minimum specs and I will check. Let me know hot to check the graphics card.
Offline HoY
  •  18 18
« Reply #16 on: February 01, 2017, 10:36:37 PM »
Just ran it through flawlessly with your script, thank you very much!
« Reply #17 on: February 02, 2017, 08:52:18 AM »
This link should help Pedio,
http://www.machsupport.com/software/mach4/#tabs-3
Google "how to find graphics card specs" and add your operating system to the end. Like this......... how to find graphics card specs windows 8
Offline Pedio
  •  200 200
« Reply #18 on: February 02, 2017, 12:39:43 PM »
My graphics card is 4095mb however, I am running two displays off of the card. Should that make a difference? I have one beside the computer where I can do a lot of work needing the keyboard and the other is a touch screen beside the machine for doing motion control. I can throw the screens between the two monitors.
« Reply #19 on: February 02, 2017, 02:12:42 PM »
Well, it will definitely make a difference. How big of a difference depends on what it is displaying. But more troubling than a second monitor is what all apps and processes are running? The PC used for Mach should be dedicated to Mach and Mach alone and not have any apps installed (anti-virus, CAD/CAM, etc.) not needed by Mach.
