Hello Guest it is November 03, 2026, 02:03:43 AM
Author Topic: Auto stop on spindle overload.  (Read 21509 times)
Re: Auto stop on spindle overload.
« Reply #10 on: October 23, 2017, 04:33:14 PM »
Here is part 2 https://www.youtube.com/watch?v=qaacj7kBw1s
I never tried mach3 for milling mode, only have cnc lathe.
« Reply #11 on: October 26, 2017, 08:00:05 AM »
Here is part 3 ,  I had some problems , so in part 4 I found solution
https://www.youtube.com/watch?v=_i0zlWfJIYA
« Reply #12 on: October 27, 2017, 03:40:57 AM »
Offline rcaffin
  •  1,073 1,073
« Reply #13 on: October 30, 2017, 05:36:53 AM »
Can't help with the actual spinning bit, but I did use a signal from the spindle PS to allow the M3 and M4 commands to check whether the spindle PS was alive. It has a magnetic breaker on the mains input which sometimes triggers at power-up. That does not help with forgetting to put the M3 command into the program - but I figure that is part of the learning process.
Roger
