Hello Guest it is October 23, 2026, 04:11:00 PM
Author Topic: Continuously run rotating axis in Mach3?  (Read 6645 times)
« on: December 07, 2016, 01:31:56 PM »
Is it possible to tell Mach3 to continuously to run a rotating axis at a specified speed?
In some cases, it is useful to be able to use a CNC milling machine as a lathe. I have a three axis CNC router with an additional table with two rotational axles. I would like to be able to tell Mach3 to run the B axis continuously at a high speed and at the same time move the other axles at a low speed. The idea is to use the B axis as the spindle in a lathe.
Is it possible to do this, using G-code, VB commands or some other way?
My milling machine looks like this:
http://www.ebay.com/itm/271434433386
Best regards,
Daniel
