Hello Guest it is October 22, 2026, 01:52:29 PM
Author Topic: Is somebody here who has expiriance with a mach4 handwheel  (Read 19698 times)
Offline beat
  •  15 15
« on: December 03, 2016, 12:29:48 PM »
Good evening
I've a question
Have somebody a handwheel togheter with mach 4 connectet?
Is this possible and which hand wheel is it?
I have a smooth stepper with 3 parallel ports.
all handwheels i found  was just for mach 3.
Thank you for our help.
Kind regards
Bear
Re: Is somebody here who has expiriance with a mach4 handwheel
« Reply #1 on: December 03, 2016, 01:44:58 PM »
Hi Bear
I use a Vista CNC - iMach PS1A-S Pendant which works wonderfully with Mach 4. I have nothing to do with the company except as a happy customer.
http://www.vistacnc.com/
Steve
« Reply #2 on: December 03, 2016, 01:56:01 PM »
You can interface any MPG that can connect to a controller.  For example you can connect a four wire 5V MPG to Mach4 using the ESS, or you can interface it to Mach4 with a Pokeys device.  You must configure Mach4 but the hand wheels do work just fine.  If you buy a Vista MPG it comes with a plugin just put the plugin in the right directory and enable the plugin and it is all setup.  Clearly that method is the fastest and you do not need to write LUA code to make anything work as that is all embedded in their plugin.
Russ
Offline beat
  •  15 15
« Reply #3 on: December 03, 2016, 03:15:22 PM »
Ok, thank you for the information, this vista wheel seems not bad. First i will read on this page to choose the best wheel.
For what can i use d display on the wheel, are you recommend a display?
Offline Pedio
  •  200 200
« Reply #4 on: December 03, 2016, 09:45:46 PM »
I use the shuttlepro. Support is built into M4. Very flexible!
« Reply #5 on: December 04, 2016, 12:40:40 AM »
Hi beat,
I've just come inside from having wired up my machine to ESS, M4 and just loaded the M4 firmware and plugin
for my CncVista P1A pendant. I've had it for a few years on M3 and PP but can be upgraded to M4, painlessly no less!
Never used Velocity mode much with M3, just couldn't get the right 'feel'. Much, much better with M4 and it makes a real
groovy sort of sound when jogging, luv it!
« Reply #6 on: September 15, 2019, 11:41:26 PM »
I have mach 4...running my plasma table on it but i would love a handwheel......i have an ESS smooth stepper....any recomendations for a bad ass handwheel compatible with mach 4 and my ESS? What handweels are good?  Thank you for your help guys 😁👍
« Reply #7 on: September 16, 2019, 12:03:49 AM »
I still use a VistaCNC P1A pendant with Mach4 and it works well.
« Reply #8 on: September 16, 2019, 12:47:43 AM »
Is that the latest?
Do you think the ebay wireless one will work? It says its for mach 3
This one ....
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F283492904719
« Reply #9 on: September 16, 2019, 12:50:33 AM »
 Ut have any attempts to use it for mach 4 been made ?
