Hello Guest it is November 13, 2026, 09:40:30 AM
Author Topic: mach3 command line parameters  (Read 13853 times)
« on: November 12, 2016, 06:39:00 AM »
I know that I can use /p to select the profile I'm starting with
(thanks to this post https://www.machsupport.com/forum/index.php?topic=10421.0)
like for example:
> c:\mach3\mach3.exe /p smoothstepper
my question is, what other "parameters" are there?
is there somewhere i can find a "list" of them?
thanks for the trouble.
Re: mach3 command line parameters
« Reply #1 on: November 12, 2016, 06:58:56 AM »
I have started a document to address your question to be inclusive of what has been posted over time on parameters.
That said,
I can create a thread so others can review it and comment and after updating  put it into Members Doc's.
« Reply #2 on: November 13, 2016, 07:35:36 AM »
That said,
that would be great, thanks
« Reply #3 on: November 13, 2016, 07:53:25 AM »
Lets see how much interest there is and if others will contribute.
Attached for user  comments.
« Reply #4 on: November 14, 2016, 03:24:42 AM »
Hey Rich,  I may have misunderstood the original question and forgive me if I have, but I believe the OP was asking about command-line parameters to start the Mach3 program, not the g-code program itself.  In the post, he gives the example:
This would start the program with a profile called "smoothstepper".  Are there other command-line switches such as this?  I'm curious to know about them as well.
That said, I love the document you've produced.  It's very informative.  I just wish I had the creativity to understand how I might use parameters in my code, but I am simply using a CAD program to create my g-code files.
Highspeed1964
« Reply #5 on: November 14, 2016, 04:26:55 AM »
I don't know.
That's why I have asked for comments. and also tried to define parameter and variable.
Not sure what  the document will include in the end. It will not be a how to do on scripting.
I'll waite for user comments and go from there.
