Hello Guest it is November 14, 2026, 03:20:08 PM
Author Topic: About V.B. script  (Read 23399 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: About V.B. script
« Reply #10 on: November 09, 2016, 07:10:37 AM »
try the following in CB
Shell "echo " & Chr(7), 2
  •  9,377 9,377
« Reply #11 on: November 09, 2016, 07:26:31 AM »
For me it does nothing other than report the error...
Error on line: # - File not found.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #12 on: November 09, 2016, 09:03:37 AM »
what flavor windoze Tweakie? I'm on XP here.
  •  9,377 9,377
« Reply #13 on: November 09, 2016, 09:26:21 AM »
This PC is Win10 Pro.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #14 on: November 09, 2016, 09:31:23 AM »
Can you run a cmd window and type:
<Ctrl>G<return>
does that beep?
  •  9,377 9,377
« Reply #15 on: November 09, 2016, 09:45:58 AM »
It does Beep but I suspect that it is only error notification of '' is not recognized as an internal or external command, operable program or batch file.
n.b. Shell "calc " & Chr(7), 2 opens the calculator so the Shell command performs OK it just baulks at echo.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #16 on: November 09, 2016, 10:16:00 AM »
OK - but at least that shows the beep capability is there.
In the cmd window type:
help
you should get a list of all the internal commands - is echo in there?
alternatively you could just try:
echo <Ctrl>G<return>
if not - it looks like echo is not an internal command in W10
« Reply #17 on: November 09, 2016, 10:50:22 PM »
Thanks everybody for the advice....
