Hello Guest it is November 17, 2026, 01:58:25 PM
Author Topic: image flipping  (Read 9369 times)
Offline Sabre
  •  11 11
image flipping
« on: November 03, 2016, 05:57:25 PM »
  I am not sure if this is a Mach3 or an Aspire question, but here it goes.
I recently installed Aspire.  When I finish creating an image, i have to reverse it before I can calculate tool paths otherwise it cuts backwards on the table. It appears to be flipped right side to left, but not top to bottom.  Is there a button or something in Mach 3 or Aspire that needs to be checked so it will cut the image as drawn on the screen without having to software / machine reverse it?
I have a 6040z with no switches.  I basically center the bit on the board that i am working and zero X,Y and Z making center of the board home on each piece. Hope that makes since.
Thanks for any help or suggestions in advance
Re: image flipping
« Reply #1 on: November 03, 2016, 06:31:36 PM »
You're machine is most likely set up with the left to right axis backwards.
Offline Sabre
  •  11 11
Re: image flipping
« Reply #2 on: November 03, 2016, 07:32:49 PM »
Thanks. That's exactly what it was. i looked right at it and still did not see the "x"  Thanks
