Hello Guest it is September 09, 2026, 11:28:52 PM
Author Topic: Backlash compensation  (Read 15834 times)
« on: March 16, 2006, 03:26:08 PM »
I notice in the Mach3 manual that backlash compensation is said to be only useful for drilling and turning where the operation can be approached from the same direction.
Why cannot backlash compensation be designed that compensates for the reversing of the lead screw when in continuous cutting?
Re: Backlash compensation
« Reply #1 on: March 16, 2006, 04:27:11 PM »
It will at this time I  think ...
www.newfangledsolutions.com
www.machsupport.com
Offline khalid
  •  213 213
    • My Wood carving
« Reply #2 on: June 06, 2010, 09:01:47 AM »
Is it true.. Is it implemented in the latest version Mr.Barker?
« Reply #3 on: June 06, 2010, 12:43:20 PM »
Wow, old thread!  8)
I will say this, I do small work in aluminum, plastics, etc. and backlash is working correctly in Rev 3.041
I know most say it's not good to use, but I have about .002-.003 backlash on my taig mill and it works perfectly as when engraving tiny little text, (under .100") you can easily see a difference when it's on and when it's off.
