Hello Guest it is October 20, 2026, 03:02:12 PM
Author Topic: Coordinate Spaces - a Guide  (Read 71325 times)
Offline rcaffin
  •  1,073 1,073
Re: Coordinate Spaces - a Guide
« Reply #10 on: October 29, 2016, 03:15:04 PM »
Hi Rich
Comments appreciated, BUT - I don't recognise the first few pages. Are they a more recent version of the MachMill manual? Maybe I have missed out on something? URL?
Roger
« Reply #11 on: October 29, 2016, 03:56:33 PM »
 NO
No, the Mill Manual was written years ago and is as it is.
You shouldn't recognize them since they are written by me and your free to include them in your quide.
Like I said, they would be a concise writeup covering basic's which you could build upon.
Offline rcaffin
  •  1,073 1,073
« Reply #12 on: October 29, 2016, 04:32:47 PM »
Hi Rich
OK, and thanks.
The difference is that your version is written from the g-code point of view (which is perfectly valid of course), while mine is written from the 'spaces' pov. Hum ... A rather neat trick mght be to include BOTH. Look at the matter from both sides as it were. That could be good, if you are happy with that? I will acknowledge of course.
Roger
Offline rcaffin
  •  1,073 1,073
« Reply #13 on: October 29, 2016, 04:59:30 PM »
Hi Rich
You wouldn't happen to have the sources for the pics you used by any chance? I am thinking of including your write-up as a Part 2 in the doc: 'the view from the g-code side' as it were.
I would like to attribute that part to you properly. Do I just use 'Rich', or can I use a real name?
Roger
Offline rcaffin
  •  1,073 1,073
« Reply #14 on: October 29, 2016, 07:03:50 PM »
Hi Rich
I have been trying to integrate the two versions, but it is difficult. I may or may not succeed. I hope you don't mind if I fail. But a couple of the diagrams might be useful if you want to make them available.
Roger
« Reply #15 on: October 29, 2016, 10:14:08 PM »
Because g code is "basic" to any controller.
This needs to be added to what I wrote:
All contollers have commands to control a machine and although
they are rather generic each controller has dilects of G code and even some propriatary ones. The following are basic Mach3 G codes / commands related to Work Offsets.
I tried to capture what is shown in hundreds of pages of the major manufacturing manuals and books.
Just what where does one find coordinate "space" as I don't remember ever seeing that in all the cnc material I studied. Coordinates / planes/ etc. are all mathematical based.Sorry i am just having problems with the "space" terminology......that's why your having trouble integrating maybe.
Keep working at it...it's your write up. ;D
I drew them myself in cad to pictorialy show what was written.
Put it where you want ( not there my friend  :D) ..........it's your write up. RICH is fine.
Diagrams for what? Can you be more specific?
Offline rcaffin
  •  1,073 1,073
« Reply #16 on: October 29, 2016, 10:30:41 PM »
Hi Rich
Ah - OK, I get you. Yes, I am coming at it from the maths PoV for sure. My background.
With that in mind ... I will revisit.
Diagrams I can do.
Roger
Offline rcaffin
  •  1,073 1,073
« Reply #17 on: October 30, 2016, 02:10:54 AM »
My thanks to Rich and Robert.
An updated version is attached.
Roger
« Reply #18 on: October 30, 2016, 09:48:25 AM »
Something you may want to use  /  modify for your next update.
Hopefully captured your intent.
I would strongly suggest you genericaly explain the concept.
Consider:
- Default setup on startup can change any description.
  So define you starting basis of the write up so other stuff
  satisfies some basis, if you don't a reader may constantly
  struggle to relate. OR start from manual to some level of setup
  automation.
- You have workspace...is there a fixture space?
  Workpace can be inclusive of fixtures, but if multiple fixtures
  are used they could be individual workspaces ie; G54 on startup, the
  G5x for others, in fact G54 variables can be "0".
  Now G5x is global and G52 is local. G52 is relative to the CURRENT
  G5? workspace offset. It is usualy used as a temporary controlled
  point offset in programming. SO be carefull in examples.
  G5x WORK offsets replaced the legacy code of G92, but as you see in
  diagnostics there is only a G92 offset.
- BTW, I think I read were MAch parameters were based one of Fanuc's
   controller.
Just some thoughts,
Offline rcaffin
  •  1,073 1,073
« Reply #19 on: October 30, 2016, 02:47:16 PM »
Hi Rich
Thanks. Appreciate feedback. Still working on it.
Roger
