Hello Guest it is November 22, 2026, 03:27:29 PM
Author Topic: Z axis not working  (Read 7706 times)
Z axis not working
« on: October 12, 2016, 04:20:58 PM »
I have a KFLOP board and i'm using Mach3, other axis are working just fine but Z axis isn't. It's position doesn't even change when I try to do so on the Mach3 interface. This probably won't be enough for you guys to help so if you need any more info, just let me know and i'll deliver.
Re: Z axis not working
« Reply #1 on: October 13, 2016, 04:47:25 AM »
If it is not changing in Mach when you command a move then it sounds like the Axis is not enabled in Mach.
Not sure how you set up the axis with the kFlop but check you have the Z enabled in Ports and Pins.
