Hello Guest it is October 21, 2026, 06:49:28 PM
Author Topic: Mach3 or Mach4 MDI Serial Input  (Read 9117 times)
« on: October 01, 2016, 11:39:41 PM »
Hello Everyone,
I am trying to find a way to send Mach 3 or Mach4 (Im Flexible) MDI commands threw a serial interface.
I have searched the forums but mostly find results for modbus.
Any ideas will be very much appreciated.
Thank You
-Adam
Re: Mach3 or Mach4 MDI Serial Input
« Reply #1 on: October 03, 2016, 05:32:28 AM »
I'm not sure is the short answer.
The longer answer is I think its possible.
If you sent a text string corresponding to a Gcode line then Mach could execute that
line by line.
If using M3 then something like:
while(true)
   gcodeLine=(a text string from serial input device)
   if(gcodeline !='EOF')then
         code(gcodeLine)
   else
          break
   end
end
Please not my VB skill is absolute rubbish and the chances of that working as is nill but
the idea should work.
I have only recently bought a licence for Mach4 so can't say for sure that this will work
but there is a 'serial plugin' in M4 which sounds rather hopeful for what you wish to achieve.
Loop
Get some serial data from the plugin;
construct a Gcode line from that data;
mc.mcCntlGcodeExecute(inst,yourGcodeLine)
end loop.
The Lua scripting language in Mach4 is a bit baffling to start with but its ultimate flexibility
and power exceeds VB. If you're going to write scripts and so on I think Lua is where you
should invest the effort. Certainly that was the conclusion I came to. Whereas Mach3 is good
Mach4 is shaping up to being brilliant.
« Reply #2 on: October 03, 2016, 12:30:17 PM »
Why do you need tp do MDI (Manual Data Input) by Serial interface?
Mach3 was not designed to use a Serial input format.
