Hello Guest it is November 22, 2026, 03:44:40 PM
Author Topic: Cutting smaller  (Read 42531 times)
Cutting smaller
« on: September 22, 2016, 12:45:55 PM »
Using MACH 3 Ver. R3.043.062, USB Smooth stepper, PMDX 126,134 & Gecko 203V drives.
The motors have been tuned the problem is all cuts are 4 thousands smaller than they should be. The code checks out fine. Is there a setting in MACH that could be causing this problem?
Bill I
Offline Davek0974
  •  2,606 2,606
Re: Cutting smaller
« Reply #1 on: September 22, 2016, 01:05:16 PM »
4 thou?
In both directions?? Could be cutter wear, not a 100% accurate tool diameter?
Re: Cutting smaller
« Reply #2 on: September 22, 2016, 02:06:54 PM »
The cutter used is new and yes the cut is smaller in both X and Y .
Offline Davek0974
  •  2,606 2,606
Re: Cutting smaller
« Reply #3 on: September 22, 2016, 02:08:31 PM »
Have you done axis calibration using accurate measuring tools over a reasonable distance?
Re: Cutting smaller
« Reply #4 on: September 22, 2016, 02:46:29 PM »
Yes  axis calibration has been done.
Re: Cutting smaller
« Reply #5 on: September 22, 2016, 02:49:27 PM »
What kind of machine, and what are you cutting? Climb or Conventional?
Re: Cutting smaller
« Reply #6 on: September 22, 2016, 03:48:54 PM »
Custom built CNC  Cutting MDF and plywood I cut in both Climb and  Conventional.
This is a new controller I never had this problem with  the previous controller.
Re: Cutting smaller
« Reply #7 on: September 22, 2016, 05:20:13 PM »
Tool diameter set correctly?  Is the tool not the size you think?
Re: Cutting smaller
« Reply #8 on: September 22, 2016, 07:09:47 PM »
Using 1/4" cutter  1st thing I checked was tool diameter.
Offline Davek0974
  •  2,606 2,606
Re: Cutting smaller
« Reply #9 on: September 23, 2016, 01:28:07 AM »
Just a query - 4 thou on MDF - thats 0.1mm !
I would not think accuracy on MDF is possible in that range TBH.
I would be inclined to change the tool diameter using the wear factor (if used) by 2thou and try again but I'm still unsure if it is really possible.
