Hello Guest it is October 21, 2026, 05:47:55 PM
Author Topic: UC100, exchanging Z axis for A axis  (Read 12386 times)
« on: September 21, 2016, 03:00:57 PM »
I have a UC100 coupled to a 3 axis Sherline mill.
The Z axis step and direction output from the UC100 has recently failed.  X & Y axis working ok.
(It would appear that the processor in the UC100 is not user replaceable and a new UC100 is around £150!)
I can go into Ports & Pins to enable the A axis and setting Step and Direction pins to 8 & 9.  However . . . . . . . . .
Is there a way of fooling Mach3 to output Z axis step and direction info to the currently unused the A axis?
Re: UC100, exchanging Z axis for A axis
« Reply #1 on: September 21, 2016, 05:18:42 PM »
Don't know anything about the UC100 but is it not possible just to set the Z Axis in Machs Ports and Pins to use the ones required (8 and 9)?
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: September 22, 2016, 01:28:59 AM »
Is it the UC100 or the BOB?
They are currently £84 at CNC4YOU :)
  •  9,374 9,374
« Reply #3 on: September 22, 2016, 01:45:27 AM »
I think you need to add postage and VAT to that price Dave.
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: September 22, 2016, 02:02:44 AM »
ok so its about £110 all-in :)
  •  9,374 9,374
« Reply #5 on: September 22, 2016, 02:17:18 AM »
« Reply #6 on: September 22, 2016, 02:44:01 AM »
Thanks Hood,
Yes you are right.  Simply a case of assigning Z axis to pins 8 & 9.
Save myself £100 ish
Andy
