Hello Guest it is November 22, 2026, 07:06:43 PM
Author Topic: Wrong way "Z"  (Read 21049 times)
Wrong way "Z"
« on: March 15, 2006, 06:46:27 PM »
Hey guys,
I am setting up a Taig Lathe with a CNC conversion package and everything is coming along but my "Z" movement seems to be backwards both in jog and program mode (ie numerical increase as the tool advances toward the headstock) .  I am using a DriveMaster 3 axis controller and Mach3 Turn.  I think my config settings are all correct but I must be missing something. Any suggestions?
Re: Wrong way "Z"
« Reply #1 on: March 15, 2006, 07:59:31 PM »
under the ports and pins change the Active high state of the Z axis Dir pin :)
That should fix you right up.
www.newfangledsolutions.com
www.machsupport.com
Re: Wrong way "Z"
« Reply #2 on: March 16, 2006, 06:06:38 AM »
That did the job!  Thank you so much.
Re: Wrong way "Z"
« Reply #3 on: March 16, 2006, 06:08:18 AM »
Great!
www.machsupport.com
Offline Glenn
  •  129 129
Re: Wrong way "Z"
« Reply #4 on: April 01, 2006, 04:17:32 PM »
   Hi Brian, I'm new to the cnc fomat, so if I have my lathe set up with Mach 3 Lathe, and my z axis is going opposite the jog direction that I have arrowed, it is probably not a good idea to just go to homing and limits,check the x and z axis to be reversed? Is this what causes my  drives to fault after jogging a short distance (maybe an inch or two at the most?)  I have had them set this way for 2 months and have never been able to run the saddle of the lathe the full length of the bed.
   In your reply to Wrong way "Z", you said to go to ports and pins, but where to go from there? Is it motor output, input signals, or output signals? It is all a foreign language to me, but anxious to learn!
    Thanks, Glenn
Don't assume anything.....it'll make a Manager out of U and Me!
Re: Wrong way "Z"
« Reply #5 on: April 02, 2006, 04:39:54 PM »
To change the Axis Direction go under ports/pins / motor output and change the Dir pin active high state for that axis and you should be good to go...
What type of moptors are you running?
Brian
www.machsupport.com
Offline Glenn
  •  129 129
Re: Wrong way "Z"
« Reply #6 on: April 04, 2006, 06:11:53 PM »
Brian, thanks alot! you got me straightened out!
