Hello Guest it is October 03, 2026, 08:07:38 PM
Author Topic: G04 hangs up  (Read 10802 times)
G04 hangs up
« on: August 28, 2016, 02:33:54 PM »
Hello all, I am setting up a (new to me) router. I have all the axis motors and I/O working properly. When I first started the spindle M3S5000 it powered up and ran to speed, The dwell LED continues to flash for several minutes.  I entered M5 and the spindle stayed powered up. I hit reset and the spindle stopped. I wrote a small program (below) and it looks like the problem is actually with the G04 timer.
Spindle dwell parameter is 0
N10 G04 P5
N20 M3 S5000
N30 G04 P5
N40 M5
The program hangs at N10 so the spindle never turns on, The dwell LED flashes till I hit reset.
Does anyone have any idea what the problem could be?
Thanks in advance, Dave
Windows XP
USB motion card HXC MK4
Chinese VFD and Stepper drives
Mach3
Re: G04 hangs up
« Reply #1 on: August 28, 2016, 05:25:59 PM »
Just a guess, but your motion controller may not support G04.
Re: G04 hangs up
« Reply #2 on: August 28, 2016, 06:15:51 PM »
Thanks for the very quick response Gerry!
I uninstalled Mach3 and did a clean install, I then loaded the Machmill profile, With nothing configured I loaded the Gcode test and it worked ok. I configured the motion controller plugin, ran the test and it was ok. I then configured each axis motor and ran the test at each configuration and it was good. With everything configured and ready to run I ran the test and it worked ok no more G4 problems. I powered down the controller and the PC. The G4 problem is back. I tried every Machmill.XML back up and the problem returned in each one. I loaded an unconfigured Mill profile ran the test and it worked ok.
Re: G04 hangs up
« Reply #3 on: August 30, 2016, 06:48:59 AM »
Have you tried g04 p5000?
Some motion controllers work in seconds delay, some in milliseconds , changing the checkbox on the general configuration tab does not change the motion controller settings
Worth a try.
Rob
Rob
Re: G04 hangs up
« Reply #4 on: August 30, 2016, 05:40:33 PM »
Thanks Rob, I think I just got it fixed, I used auto tune for the step counts, and I accepted a value with a decimal. Apparently using a non whole value messes up the controller.
