Hello Guest it is November 13, 2026, 04:44:17 PM
Author Topic: PWM Settings for Pokeys57CNC  (Read 41969 times)
Offline NeoTO
  •  504 504
    • PoLabs
Re: PWM Settings for Pokeys57CNC
« Reply #10 on: September 12, 2016, 01:06:25 AM »
As I already responded in the same message on the ticketing system, we are sorry for your lost workpieces.
As noted there, we will be doing a test procedure to try to replicate the jogging problems you have to avoid having such issues in the future. As was in the past, all issues that we are able to replicate are solved ASAP.
« Last Edit: September 12, 2016, 01:08:22 AM by NeoTO »
Offline dude1
  •  1,253 1,253
« Reply #11 on: September 12, 2016, 01:48:15 AM »
I have one it works fine, any problems they fix with in 24 hours if they can reproduce them. there are other factors that can make things go wrong
« Reply #12 on: September 12, 2016, 02:16:40 AM »
hi
ok then give me a tip please
I aleady use a other PC, latest mach 3 version
thx
Peter
Offline dude1
  •  1,253 1,253
« Reply #13 on: September 12, 2016, 02:28:07 AM »
are you using the ethernet cable or USB, I have different hardware I use pin 20 for pwm. pin 17 would not work as it should on the G540 when I first set it up, there is a reason for it. that was the only problem I have had with it, but they responded straight away on the support ticket within 24 hours. what's good as they are 14 hours in my past
other than that just try pin 20
« Reply #14 on: September 12, 2016, 05:54:27 AM »
pwm is solved
and also spindle override
my problem is that when a job is finished and spindle turns down and wait for me when im back in the room that in this time where mach3 and pokeys have nothing to too the felt in a "icall it Trance"
jog is then slowly and one of my two x axis motors are crying and stand still at jogging
not always the same motor, one of the two x axis motors, master or the slave one
make all powerless an restart and all working fine
so I think this is only a problem off v2 plugin
I go back to v1 and manage spindle by hand
but this "trance" is also in v1 now I must see
I forgot to shutdown everythink before mill next
and my workpiece was damaged this weekend
and the PC is a I7 with ssd  and 16gb ram
win7 64bit
all energy power savings are disabled
direct lan cable connected to pokeys
fixed ip's
when the problem is then only the x master and slave axis have the problem
I send you later  pokes.xml and motor settings from mach3
