Hello Guest it is September 17, 2026, 09:28:47 AM
Author Topic: Mach3 Turn Wizard error - *** Roughing Cut = 0 *****  (Read 18790 times)
« on: August 22, 2016, 04:38:00 PM »
I am getting the following error displaying in the Mach3 Turn Wizard - *** Roughing Cut = 0 *****.
This started when I tried using the wizard to do some turning. No matter what I do it will not disappear, even closing the program and restarting the computer does not help.
Any thoughts from any one?
Re: Mach3 Turn Wizard error - *** Roughing Cut = 0 *****
« Reply #1 on: August 22, 2016, 04:45:51 PM »
Sounds like you have the roughing cut depth set to zero.
« Reply #2 on: August 22, 2016, 04:48:21 PM »
Yes, I would agree  :) The only problem is I cannot change the value in the roughing cut depth box. I enter a value, press enter and then the value disappears and goes back to 0.
« Reply #3 on: August 22, 2016, 04:51:51 PM »
Can you enter values into the other boxes ok?
« Reply #4 on: August 22, 2016, 04:54:38 PM »
Thank you for your help.
I cannot get values in to Roughing Cut Depth and Finish Feedrate boxes on the OD turning Wizard.
« Reply #5 on: August 22, 2016, 04:58:33 PM »
All the rest are Ok? strange, maybe a corrupt wizard screenset.
Can you zip and attach the Turn Addons folder and I will take a look. You will find it in the main Mach3 folder.
« Reply #6 on: August 22, 2016, 05:02:35 PM »
See attachment. Thanks  :)
All the rest are ok. The other wizards work fine.
« Reply #7 on: August 22, 2016, 05:11:51 PM »
Ok is it the OD Turning one? Seems fine for me using your addons.
« Reply #8 on: August 22, 2016, 05:20:03 PM »
It is the OD turning / OD fillet wizard that causes the issue.  ???
« Reply #9 on: August 22, 2016, 05:31:36 PM »
Not sure where the problem could be then as I used the wizards you attached and could enter values in no problem.
The code produced does seem to have issues with the arcs but that is likely because I have tools set as rear toolpost in the tool table.
Unlikely to be your keyboard if you can enter values in to the other DROs, so afraid I do not really know what to suggest.
I have altered a couple of the wizards for my Lathe but not sure if they would work for your setup, likely I reversed the arcs, I also have set Z clearances and tool change DROs etc so it looks  a lot more complex.
 I have attached them if you want to give it a try, just unzip into the addons folder and when you load the wizards you should see Turning, which is yours and Turning1 which is mine.
