Hello Guest it is September 09, 2026, 09:32:11 PM
Author Topic: MIKRON WF3 RETROFIT  (Read 145436 times)
Re: MIKRON WF3 RETROFIT
« Reply #20 on: September 06, 2016, 12:54:07 AM »
the "high-voltage" area is finished.
« Reply #21 on: September 08, 2016, 01:00:01 AM »
i want to connect the tool changer button for the hydraulic valve and collet chuck.
how is the right way for the option automatic tool changer and a faulty operartion at runtime M3/M4 spindle or  programm.
« Reply #22 on: September 09, 2016, 03:03:25 PM »
Sorry do not understand what you are asking, seems like it may be several different things?
« Reply #23 on: September 10, 2016, 12:45:39 PM »
i want a manual button for unlock the tool clamping and i want the automatic tool changer funktionality.
- the manual button to an digital input
- the hydraulic valve for the clamping  connected to an digital output
is this the right way?
but i can`t find the settings for this funktionality.
next question..
i use the mpg modul with 2 5v analog inputs.
can i use the inputs for the SRO and FRO potis or are the only for the mpg mode ?
the CSMIO-A use 2 analog 10v inputs for the SRO/FRO potis.
« Last Edit: September 10, 2016, 12:57:22 PM by gravie »
« Reply #24 on: September 11, 2016, 02:51:03 AM »
manual page 72
i can use the mpg modul anlaog input.
« Reply #25 on: September 15, 2016, 03:48:48 AM »
a new idea for the gear chaning is to use a FALLER 180725 servo control,  4 outputs for servo modul , 4 inputs for switches, 1 output for a fixed, low spindle speed (input frequency converter).
and 2 or 3  RC jumbo servos with a torsion bar spring (same mechanical mounting as at the newer mikron WF41/51C machines)
http://www.faller.de/xs_db/DOKUMENT_DB/www/anleitungen/180725_anl_01.pdf
« Reply #26 on: September 15, 2016, 08:16:47 AM »
Hmm, very interesting.  I never knew such a device existed!  I'm interested to see how you use it on your machine.:)
Milton from Tennessee ya'll.
« Reply #27 on: September 15, 2016, 10:24:17 AM »
yes, but the VB script is the big problem for me.
use everyone the heidehain EXE 602 box with a CSMIO control unit?
after pushing the reset i received a window with failure "DS26C31 Powersupply Malfuntion".
is the power consumption to high for the encoder chanels?
« Last Edit: September 15, 2016, 10:26:35 AM by gravie »
« Reply #28 on: September 17, 2016, 10:43:30 AM »
the linear scale mistake was a inverted cable and plug ..   ::)  with the same colours, but a mirrored numbering. ???
« Reply #29 on: September 25, 2016, 06:32:35 AM »
now i can setup the software
