Hello Guest it is November 22, 2026, 05:06:22 PM
Author Topic: Door switch  (Read 6102 times)
Door switch
« on: August 19, 2016, 11:02:23 AM »
Hello
I can't set the door switch on feed hold instead of E-stop.The reason is simple It's a wood lathe and when
the part is done machining I start the spindle and I sand the piece while the spindle running. I save a lot
of time doing it. Is anyone does have an issue with this in the past. I am actually installing Mach4 + ESS
Thank you for your time
Marc-Andre
