Hello
Guest
it is
September 29, 2026, 10:02:19 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Pin-out signal to activate button function
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Pin-out signal to activate button function (Read 7402 times)
Thom2000
24
on:
August 18, 2016, 04:49:32 PM »
Hello Group,
I would like to activate the Single Block button in Mach3 using a 12v input signal.
Is this possible using a brain ?
Thank you in advance.
TC
Logged
Carnoustie, Scotland
Re: Pin-out signal to activate button function
Reply #1 on:
August 18, 2016, 05:11:49 PM »
Is your breakout board/ external controller/ whatever capable of taking 12v?
If it is then yes you can use a brain or you could use the macropump.
Logged
Print
Pages:
1
Go Up
« previous
next »
