Hello Guest it is November 24, 2026, 03:11:58 PM
Author Topic: Mach4 Tangential  (Read 7031 times)
Mach4 Tangential
« on: August 13, 2016, 07:44:58 AM »
1) Does it work?
2) If it does work, does Constant Velocity work in tangential mode?
3) If (1) and (2) are true, does it work through SmoothStepper?
Currently using Mach3 v3.043.022 - tangential fails in any version newer than that.
Offline smurph
  •  1,575 1,575
Re: Mach4 Tangential
« Reply #1 on: August 17, 2016, 10:57:29 PM »
Brian is working on the tangential stuff right now.  CV is working.  I don't know the status of the rest of it.  But it may do what you need.  Try it out and see.  It should work with Ethernet Smooth Stepper fine.  Or any other motion device that Mach 4 supports.
Steve
