Hello Guest it is October 25, 2026, 10:13:51 AM
Author Topic: Can mach4 close loop control  (Read 12442 times)
« on: July 26, 2016, 12:55:27 AM »
Kindly tell us Mach4 can support full close  loop control over axis while motion or only monitor axis if support kindly tell how to configure in mach4.
« Last Edit: July 26, 2016, 01:05:56 AM by rohitk14 »
Re: Can mach4 close loop control
« Reply #1 on: July 26, 2016, 08:02:43 AM »
True closed loop support in Mach4 requires an suitable interface
with a plug-in that supports closed loop. Currently I can think of
one example that is actually available:
http://www.vitalsystem.com/portal/motion/dspmc/dspmc.php
Steve Stallings
www.PMDX.com
Offline mark4
  •  167 167
« Reply #2 on: August 01, 2016, 10:38:19 PM »
hi
the csmio/ip-a controller from cs-labs is analog +/- 10v closed loop controller. i believe the other control csmio/ip-s does also but i am sure of the ip-a the only draw back is the plug in for mach 4 isnt as far along as i would like i really like the product but there are a few things in lathe that are not supported yet and it has been quite some time. that being said i am using the controller for my mill upgrades and we shall see when the updated plugin comes out.
