Hello Guest it is November 13, 2026, 01:31:30 PM
Author Topic: Mach3 Spindle output stopped working  (Read 8934 times)
« on: July 24, 2016, 10:37:13 PM »
Just fired up the lathe to do a bit of work and the spindle control has gone. It has been working perfectly fine for about the last 2 years since I put in a VFD to control the motor. Chased the issue all the way back to the pinouts on the parallel port and there is no 4.3v when I turn on the spindle. If I change the same ports that I use for the spindle to say coolant output it switches on and off but when I go back to spindle there is still no output. It seems to be a software issue. Any ideas?
Cheers,
Fil
  •  9,377 9,377
Re: Mach3 Spindle output stopped working
« Reply #1 on: July 25, 2016, 12:49:54 AM »
Two thoughts come to mind…
It could be an accidental change to your setup – perhaps go to Operator / Restore Settings, follow the onscreen instructions to go back to an earlier set-up and see if that solves the problem.
Alternately it could be failure of that particular pin on the parallel port – perhaps change your settings, and wiring, to use another pin (assuming you have an unused output pin available).
