Hello
Guest
it is
October 26, 2026, 05:48:04 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
need help! Newbie's problems
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: need help! Newbie's problems (Read 26832 times)
Re: need help! Newbie's problems
Reply #10 on:
May 23, 2007, 03:29:58 PM »
What is the
steps per
on the X axis?
Logged
efimius
8
Reply #11 on:
May 23, 2007, 03:34:03 PM »
20000
Logged
Reply #12 on:
May 23, 2007, 03:39:05 PM »
Try it at 22727 and see what happens.
Logged
efimius
8
Reply #13 on:
May 23, 2007, 03:50:03 PM »
What is the mystic number?
200 steps X 10 micSteps = 0.1 Inch Then
1 Inch = 20000, it's wrong?
Thank you.
Logged
Reply #14 on:
May 23, 2007, 03:54:51 PM »
you have 20,000 and it moves 22mm when you command it to move 25 so I just wondered what it would move if you put 22727.
Logged
efimius
8
Reply #15 on:
May 24, 2007, 06:10:30 AM »
Hood,thank you very much.You guide me to the
right direction.
I caught out that my screw drive have 5/8" diameter,
then it's
TPI = 11
, and
pitch is 2.308 mm
I did the changes in
Step per
and now all works
properly!
Thanks!Best regards.
efimius.
Logged
Reply #16 on:
May 24, 2007, 12:01:25 PM »
Glad you are sorted.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
