Hello Guest it is November 22, 2026, 11:23:41 PM
Author Topic: skipping around a g-code file  (Read 18577 times)
Offline olf20
  •  325 325
Re: skipping around a g-code file
« Reply #10 on: July 17, 2016, 06:01:11 AM »
Also when you do the RFH do not hit stop!
First use feedhold then stop.
Hood has probably mentioned the problem.
I don't remember how I set mine up but the
manual will tell you.
Also what version are you running. There was
versions that RFH was broken.
For most 062 works well, but that somewhat
depends on the scope of your work.
Hope this helps!!
olf20 / Bob
« Last Edit: July 17, 2016, 06:09:12 AM by olf20 »
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
