Hello Guest it is November 27, 2026, 09:48:37 AM
Author Topic: PMDX-412 SmartBOB-MiniUSB announce  (Read 19397 times)
« on: June 24, 2016, 06:53:14 PM »
The new PMDX-412 SmartBOB-MiniUSB motion controller for Mach4 is now shipping.
For details see: http://www.pmdx.com/PMDX-412
This new controller offers the simplest, lowest cost way to create a Mach4
machine controller.
It provides the controller, pulse engine, breakout board, and plug-in terminal
strips. External breakout boards or terminal strips are not needed.
It can self mount directly to the wall of your control enclosure and includes
a dress panel for the outside of the enclosure.
The I/O available is equivalent to one parallel port and includes 4 axis step
and direction outputs, 4 logic level output signals, and 5 input signals including
the E-Stop function.
The output signals can be used with our PMDX-104 relay board or with
solid state relays.
The inputs accept mechanical switches, NPN sensors, or 5 volt logic signals.
PNP sensors can be used by adding our PMDX-105 board.
VFD spindle inverters can be controlled by adding our PMDX-407 board.
Stay tuned for more SmartBOB products in the future.
Steve Stallings
www.PMDX.com
Steve Stallings
www.PMDX.com
