Hello Guest it is November 24, 2026, 03:12:09 PM
Author Topic: Bitmap buttons left up action  (Read 18802 times)
Re: Bitmap buttons left up action
« Reply #10 on: June 23, 2016, 07:34:49 AM »
At a quick glance you are trying to put the bitmaps onto "childPanel" that does not exist, try "panel" thats already declared ;-)
another thing thats ver good practice is to use "event:Skip()" within each event at the end
DazTheGas
Shoot! That is left over from when I tried seeing if putting another panel on top would fix the problem. Even with those lines fixed it still wont work after leaving the edit mode :/
« Reply #11 on: June 23, 2016, 08:25:58 AM »
Interesting. Tacking on enabling/disabling the panel to the controls enable/disable toggle button fixed the problem.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #12 on: June 23, 2016, 10:02:45 AM »
When you leave the editor go into view then load screen and reload your screen, this will run the code in the panel, for some reason doing panels like this do not refresh themselves after editing.
DazTheGas
