Hello Guest it is October 26, 2026, 01:52:40 AM
Author Topic: Huge feedrate error  (Read 10880 times)
Huge feedrate error
« on: June 12, 2016, 04:56:16 PM »
Consider the following M code.  It should read the feedrate from a DRO, which is does (300), set the feedrate to 300, move to X5Y5 then back to zero.
Code: [Select]
function m200()
    local Feedrate = mc.mcProfileGetDouble(inst, 'PersistentDROs', 'droPLFeedRate', 1)
    mc.mcCntlSetLastError(inst, 'Set Feedrate')
    code2 = 'F ' .. Feedrate .. '\n'
    code2 = code2 .. 'G01 X5 Y5\n'
    code2 = code2 .. 'G01 X0 Y0\n'
    mc.mcCntlGcodeExecuteWait(inst, code2)
end
    m200()
end
It does not set the feedrate to 300IPM.  It sets it to 3IPM.  The Feedrate variable is correct.  Same thing happens if I replace Feedrate with a '300'.  So thinking that I just need to multiply the Feerate variable by 100, I try this...
Code: [Select]
function m200()
    code2 = 'F ' .. Feedrate * 100 .. '\n'
end
    m200()
end
This sets the system Feedrate to 9IPM.  Do I have a setting wrong?  Seems like the only code that will run inside mc.mcCntlGcodeExecuteWait is simple.  This one is similar.  The G31 executes but the feedrate is a fraction what it is told to be.
Code: [Select]
function m200()
    code2 =  'G31 Z-2 F100\n'
    code2 = code2 .. 'G92 Z0\n'
end
    m200()
end
The Feedrate is running at 1IPM.  Also can't get any of this to actually run by calling the M code.  It runs in the editor, but not when the M code is called.
Re: Huge feedrate error
« Reply #1 on: June 12, 2016, 05:01:45 PM »
I should also mention that if I load a gcode file that has say...F100 in it, The feedrate sets properly.  This only seems to be happening using mc.mcCntlGcodeExecuteWait.  Also interesting is that no matter what I set the Feedrate variable to, it will not go higher than 9IPM.  I can say 'F3000' or 'F900000'.  Either way, the system feedrate gets set to 9IPM.
« Last Edit: June 12, 2016, 05:04:24 PM by rrc1962 »
« Reply #2 on: June 12, 2016, 06:47:23 PM »
So....I got this M code working.  Not sure what I did, but now it works one time.  If runs as it should, but to get it to run again, I have to shut down M4.   Most of the time, I have to use task manager to shut it down.
Isn't there a way to trap runtime errors here?  It runs fine in the editor, so debugging there is of little use.
Offline dude1
  •  1,253 1,253
« Reply #3 on: June 12, 2016, 07:26:18 PM »
there is a post on the affect of each Gcode run type I will find it and post it. it's from one of the mach guys
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #4 on: June 13, 2016, 03:11:51 AM »
Have you ever considered using the registry plugin (also can be persistent) and assign a register to your dro, this can then be retrieved from within the macro.
DazTheGas
« Reply #5 on: June 13, 2016, 08:07:21 AM »
DazTheGas
Good idea.  I had not thought of that.  Could the feedrate also be set that way?  IE:  Assign the Feedrate DRO to a register and rather than posting 'F100' to mc.mcCntlGcodeExecuteWait(), just set the registry value assigned to the DRO.  Retrieving the feedrate value wasn't the problem.  Setting it was the issue.
I did get it working.  I knew the macro was running because is was setting last error.  I was just failing somewhere within.  I put message boxes after every line of code and ran it until the message boxes quit showing.  Turns out it was a case of a bad line of code.  The code looked fine and ran fine in the editor, just wouldn't run in real time.  I retyped what looked like an identical line and commented the first, and it ran fine.  This is the second time this has happened.
