Hello Guest it is November 13, 2026, 07:51:44 AM
Author Topic: Spindle S Command Not Working  (Read 8045 times)
« on: June 01, 2016, 08:49:47 AM »
Working on a VMC and my spindle won't change speed using the "S" command.  The only way I can get the spindle to change speed is to manually enter a speed into the spindle speed DRO.  I have even tried writing a G Code program that varies the spindle speed and it still has no effect.  My spindle works great M3, M4, and M5 all work correctly and the spindle is calibrated, the only issue is the S command in MDI or G Code.
Any thoughts?
-Chad
Chad Byrd
Re: Spindle S Command Not Working
« Reply #1 on: June 01, 2016, 01:46:31 PM »
Okay, problem is fixed.  I was running Mach3 R3.043.066 and switched it to R3.043.062 and everything is working just fine!! =)
-Chad
Chad Byrd
