Hello Guest it is October 24, 2026, 06:47:49 PM
Author Topic: Using Modules  (Read 25338 times)
Offline dude1
  •  1,253 1,253
Re: Using Modules
« Reply #10 on: May 29, 2016, 07:17:41 PM »
have a look at what popperbear did in his modules they work
Re: Using Modules
« Reply #11 on: May 29, 2016, 07:27:49 PM »
What he did contradicts what Daz said.  Poppabear is using an.mcc file.  Daz said to use a .lua file, which jives with basic lua documentation. I'm surprised there are not enough people using modules to warrant a blurb in the scripting manual on how to use them.  They talk about modules and how useful they are, but nothing on how to use them.
Re: Using Modules
« Reply #12 on: May 29, 2016, 07:38:20 PM »
Poppabear has this in the screen load script...
Code: [Select]
package.path = "./?.lua;c:/Mach4Hobby/Modules/?.mcc;" --where the module file is.
M = require "Module1"
Daz has this
Code: [Select]
local profile = mc.mcProfileGetName(inst)
local path = mc.mcCntlGetMachDir(inst)
package.path = path .. "\\Profiles\\" .. profile .. "\\Modules\\?.lua;" .. path .. "\\Modules\\?.lua;"
Poppabear is referencing .mcc files where Daz references .lua files.  Everything I'm digging up tells me that the module should be a .lua file.
Re: Using Modules
« Reply #13 on: May 29, 2016, 07:59:14 PM »
Found a problem in the button script.  I had theFunction(), not M.theFunction().
I can now cycle through the code in the editor and when it hits the line M.theFunction(), it goes to the function and does nothing.  I should be displaying a message box.  Running it outside the editor doesn't do anything either.  Am I trying to do something here that can't be done in a function?  Is it a scope issue?
Correction...It works in the editor.  The message box was displaying in the background.  Does not work outside the editor though.
« Last Edit: May 29, 2016, 08:03:51 PM by rrc1962 »
Re: Using Modules
« Reply #14 on: May 29, 2016, 08:31:02 PM »
OK...It's working....And here's why it wasn't.  The button script was never executing.  This has happened many times.  When I press a button nothing happens.  You assume the script has an error and commence to chase it down the rabbit hole, just to find that the script is not running.
I started out this morning with the button script on the Left Up Script.  Remembering all the trouble I've had with broken buttons, I moved the script to Left Down early this afternoon.  Never had two broken button events, but third time is a charm.  I moved it to Clicked and it all works.
Re: Using Modules
« Reply #15 on: May 29, 2016, 09:25:05 PM »
Arrrg...So now I'm just trying to call a function from another function within the module and I get this...
Code: [Select]
C:\Mach4Hobby\Profiles\Mach4Mill\Modules\ShapeWizard.lua:45: attempt to call global 'getHeader' (a nil value)
stack traceback:
C:\Mach4Hobby\Profiles\Mach4Mill\Modules\ShapeWizard.lua:45: in function 'Circle1'
[string "C:\Users\Richard\AppData\Local\Temp\le221E.mc..."]:9: in main chunk
This is the line that generates the error...
Code: [Select]
    wx.wxMessageBox(getHeader() .. getStart('0', '50') .. getStop('0') .. getEnd())
This is getHeader()
Code: [Select]
function getheader()
    gcode1 = 'G20\n'
    gcode1 = gcode1 .. 'G90\n'
    gcode1 = gcode1 .. 'G91.1\n'
    gcode1 = gcode1 .. 'M1102\n'
    gcode1 = gcode1 .. 'M1000\n'
    return gcode1
end
Re: Using Modules
« Reply #16 on: May 29, 2016, 10:16:30 PM »
When I load the module, I call sw = require(MduleName).  I think when I call getHeader(), I need to call sw.getHeader().  Sounds like a good start tomorrow.
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Using Modules
« Reply #17 on: May 30, 2016, 05:10:09 AM »
Let me try and clear this one up about modules before you awake........
Modules in Lua - wxLua are like other languages classes, now these classes hold functions (class of functions). Now when declaring these Modules wx or lua need to know where to look, this is where the package.path comes in.
Like all other languages you declare the path which is "global" so no need to keep declaring all over the place.
Code: [Select]
So lets break this down to what wxlua  sees when we require a module called newClass, first lets look in  "Mach4Hobby\Profiles\"current profile name"\Modules and look for newClass.lua  and if not found then lets look in Mach4Hobby\Modules for newClass.lua - so does it have to be .lua extension?? - nope it can be anything you want
Code: [Select]
package.path = path .. "\\Profiles\\" .. profile .. "\\Modules\\?.lua;" .. path .. "\\Modules\\?.lua;" .. path .. "\\Modules\\?.mcs;"
The above will look in the same directories but also look in the last directory for newClass.mcs  - so now we can find modules lets look at the module
Code: [Select]
local myClass = {}
function myClass.test()
    wx.wxMessageBox("Nothing to see here")
end
function test()
    wx.wxMessageBox("Still Nothing to see here")
end
return myClass
The above will create a class called myClass and declare myClass.test() as available to public to use, however the function test() is private and can only be used by the class.
Now lets load the class from mach4, first make an instance of the class and call it what you like
message = require "newClass" - wxlua will now search our path from earlier for the newClass file and make a new instance of the class called myClass contained in the file, now to use a function in the class we need to call it with the instance of the class we created "message", so to run the test function we would use message.test() - this will now run and in this case show a messagebox.
If wanted you can use many instances of the same class
message2 = require "newClass"
each one of the buttons or dro`s etc in the editor create an instance of a class for example.
DazTheGas
Time for coffee and biccy now
« Last Edit: May 30, 2016, 05:16:11 AM by DazTheGas »
Re: Using Modules
« Reply #18 on: May 30, 2016, 01:38:42 PM »
Lets say I create the same class with a slight twist...If I say message = require "myClass" and call message.test() it should return a message box saying 'Nothing to see here'.  We pass 'Nothing' to test2(), it then takes that argument and concatenates ' to see here', then returns the result back to the message box.  Shouldn't this work?
The problem isn't accessing test() from outside.  Problem is accessing test2() from within test().  They are defined within the same module, yet lua doesn't seem to think that test2() exists.
Code: [Select]
local myClass = {}
    wx.wxMessageBox(test2('Nothing'))
end
function test2(str)
    str = str .. ' to see here'
    return str
end
return myClass
« Last Edit: May 30, 2016, 01:57:19 PM by rrc1962 »
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Using Modules
« Reply #19 on: May 30, 2016, 02:44:46 PM »
I have just copied your myClass and made new module exactly the same in my modules directory and run this code
Code: [Select]
message.test()
which as expected displayed a messagebox with "Nothing to see here"
If i try to access message.test2() then it gives an error
So this is working correctly as it should.
DazTheGas
