Hello Guest it is November 23, 2026, 02:09:43 AM
Author Topic: how to config a usb port - startup  (Read 9626 times)
« on: May 27, 2016, 12:07:23 AM »
how do you connect to the usb port in the config
having trouble connecting
any help out there?
gary
  •  9,378 9,378
Re: how to config a usb port - startup
« Reply #1 on: May 27, 2016, 12:57:34 AM »
For Mach3 to communicate with the outside world via USB you would need to use a 'plugin' (http://www.machsupport.com/software/plugins/).
Perhaps if you give us more details of what you are trying to achieve and for what end purpose then we may be of more assistance.
« Reply #2 on: May 27, 2016, 10:37:05 AM »
MY ARDUINO IS PLUGGED INTO ( COM3) ON MY COMPUTER. IN MACH3 CONFIG SETTING HOW OR WHERE DO I PUT THE SETTINGS TO CONNECT TO THAT PORT?
  •  9,378 9,378
« Reply #3 on: May 27, 2016, 11:05:31 AM »
Perhaps do some forum searching to find out more information on using Modbus, this thread may get you started; http://www.machsupport.com/forum/index.php/topic,23759.0.html
also, take a look at the Modbus setup video's here;  http://www.machsupport.com/help-learning/videos-tutorials/
and Peter Homan's pdf here; http://www.homanndesigns.com/pdfs/Using_Modbus_with_Mach3.pdf
Hope this helps and please don’t shout.
« Last Edit: May 28, 2016, 12:44:39 AM by Tweakie.CNC »
