Hello Guest it is October 24, 2026, 10:58:59 PM
Author Topic: Setting Soft Limits On as the Default  (Read 21766 times)
Offline Stuart
  •  311 311
Re: Setting Soft Limits On as the Default
« Reply #10 on: June 29, 2016, 12:52:21 PM »
Thanks Daz
Thought it may be so
Pity they do not save its state in the profile , but again there may be reasons I do not know about
Btw long time Mach3 user but due to the Chinese motion controller playing silly whats its I have converted the mill to mach4 and ESS with a C25
Stuart
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #11 on: June 30, 2016, 02:24:27 AM »
With a little coding you can save the state of a button, look at the ButtonEnable() function in the Screen Load Script which is using scr.SetProperty on loadup, this combined with a scr.GetProperty and mcProfileWriteInt or String before the screen is destroyed on exit will do this for you.
DazTheGas
Offline Stuart
  •  311 311
« Reply #12 on: June 30, 2016, 02:54:04 AM »
That will take some thinking about for my 70 year old brain cell :)
Nice topic for one of your great quick tips vidieo's  ;D please
Thanks for taking the time to reply
Stuart
« Reply #13 on: July 06, 2018, 09:07:22 AM »
I am not getting this button default state to work.  I select button down and it seems that it just changes it for the moment and and does set the default.  My goal is to have keyboard and softlimits enabled by default.
i change to button down, restart and the button is not active.
thank you for any info.
« Reply #14 on: July 13, 2018, 03:41:44 AM »
something else you can use is mc.X_AXIS, mc.Y_AXIS etc to specify which axis you want. it makes your code more legible.
function autoSoftLimitsToggle (togglevalue)
    local rc = 0
    for i=0, 11 do
        if mc.mcAxisIsEnabled (inst,i) == 1 then mc.mcSoftLimitSetState (inst,i,togglevalue) end
    end
end
autoSoftLimitsToggle(1)
« Last Edit: July 13, 2018, 03:44:36 AM by cd_edwards »
Colten Edwards
www.lasernthings.ca
