Hello Guest it is November 07, 2026, 10:39:52 AM
Author Topic: OK, I give up! How do I get ACAD dxf files to open in LCAM 2.02?  (Read 64624 times)
Re: OK, I give up! How do I get ACAD dxf files to open in LCAM 2.02?
« Reply #30 on: June 08, 2007, 06:56:21 PM »
I need help! I promised a job to someone because my MachIII and plasma have done great work.
I got this drawing of a maple leaf, I import it into lazycam, and get a message saying there are splines in the drawing and it can not import it. I see nothing wrong with the drawing, though I am not an expert in autocad. I think it is a drawing issue, because my cutting table has done much more difficult stuff then this.
Does someone have a minute to look at the drawing, I will attach it.
Thank you
cody
Cody
« Reply #31 on: June 08, 2007, 08:23:53 PM »
No splines, but it's all 3D polylines, which LazyCAM probably doesn't like. This might help you out.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #32 on: June 08, 2007, 10:16:31 PM »
Hi, Cody
Your file loaded with latest ver of LC, The Offsets, Optimize and Clean aren't working very well though.
Hears a Lcam file, Your DXF took a while to load.
Hope this helps, Chip
« Reply #33 on: July 27, 2007, 04:00:17 PM »
i had the same proublem using acad 2000 and corel draw if i didnt cloce auto cad it would not open in corel
vmax549
« Reply #34 on: July 27, 2007, 06:10:53 PM »
I use AC 2000 with no problems. DXFs always load in LCAM?????? Are you by chance using blocks in your drawing?
I do a simple DXFout assign the name and it always works. Could be a process you are doing in AC that LCam does not understand yet.
I don't think Lcam can do splines yet or 3d polylines. Pretty much simple 2.5d drawings. I t will process simple polylines with no problems
Also I don't believe Lcam is network aware. It may not be able to share files that are currently open by another program.
« Last Edit: July 27, 2007, 06:19:39 PM by vmax549 »
Offline ticoe
  •  12 12
« Reply #35 on: August 26, 2007, 08:20:01 AM »
I found that I  must save, then close the dxf. file on acad before it will open an lazycam.
