Hello Guest it is November 01, 2026, 12:41:17 PM
Author Topic: Lcam Rev 2.02  (Read 68884 times)
Re: Lcam Rev 2.02
« Reply #20 on: May 28, 2007, 11:45:09 PM »
Yep i see what your saying most of what i do is turn so I'm just using yours as examples.  But i do have a question whats the advantage of doing offsets in Lcam versus using the left and right tool offset?  Beside the fact you just don't have to code them.
Wes
Have a nice Day
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Lcam Rev 2.02
« Reply #21 on: May 29, 2007, 12:31:07 AM »
Hi, Wes
Well it's a mixed bag, Trying to help de-bug LC, Mach3 G41/G42 don't lead in/out the same, LC will save allot of time in cut and pasting of g-code.
Hears a view of blade cut and Tap file of same with out lead-ins on in LC and g42 tool offset turned on in Mach3 multi cut Gcode.
The lead in look fine the lead out doesn't extend out as it should and cut's off the trailing edge, I've posted this before no time to look at it I guess..
I may be doing something wrong hear though ???
Thanks, Chip
« Last Edit: May 29, 2007, 01:04:04 AM by afn09556 »
Re: Lcam Rev 2.02
« Reply #22 on: May 29, 2007, 02:36:08 AM »
remove the rapid z retracts LC puts these in for some reason
Have a nice Day
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #23 on: May 29, 2007, 09:28:29 AM »
Hi, Wes
That seemed to help allot, Thanks,
Would have thought it would have finished the g42 tool off set even with it in there.
Thanks, Chip
Re: Lcam Rev 2.02
« Reply #24 on: May 29, 2007, 10:15:23 AM »
The Extra lines in the drawing is a bug in the importer code..
We have a bug report to the place that is doing the DXF importer code... if we don't hear from them soon we will bump them again...
Once that is fixed we will work on the offset code :)
www.newfangledsolutions.com
www.machsupport.com
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #25 on: May 29, 2007, 11:46:48 AM »
Hi, Brian
Updated LazyCam this morning, Pocketing is completing both Spiral & ZigZag Now, Thanks !!
Didn't now the bug was in the DXF importer, Thanks for the info..
I now your Working Hard all the time, Sorry for my ranting hear.
Thanks, Chip
Re: Lcam Rev 2.02
« Reply #26 on: May 29, 2007, 12:05:08 PM »
Chip looks like a bright day for ya.  Na your never suppose to retract a z until offsets are canceled.
Wes
Have a nice Day
Re: Lcam Rev 2.02
« Reply #27 on: May 29, 2007, 12:07:26 PM »
I don't think of it as Ranting.. You have helped to make it better for everyone and I think they all thank you for it :)
Keep up the good work
Brian
www.machsupport.com
Offline PaulWC
  •  125 125
Re: Lcam Rev 2.02
« Reply #28 on: June 01, 2007, 12:51:17 PM »
Hi Art,
Here is the screenshot of my current Offsets attempt.
Thanks, Paul, Central OR
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #29 on: June 01, 2007, 04:40:59 PM »
Hi, Art & Brian
LazyCam Downloaded this morning Ver 2.02
When LC opens, Layers, "Cut Rapid Hight" is 0.0000, After loading a DXF file "Cut Rapid Hight" is 60.0000, WOW Ba-beee... !!.
The 60.0000 value also appears in the Tool "Plunge Feed & Feed Rate", box's with "No Tool" selected.
It's not in the XML, It must be in the main LC code, Shouldn't it be 0 or some lesser value. ?
In Pockets "Spiral" getting the Error Below, With a 0.0625 value set in Parameter, "Tool Dir":, No Error, With a 0.1625 it work's Fine in Spiral and Zigzag ( Just Takes some time to sort-out everything } :D.
The Object to be pocketed is really Big X 407 Y 120 unit's "Meg-a Test Hear". :)
Final Error is "EndGLDraw1".
As I've stated before, It would be nice to have an indication that LC is Processing Data and a way to Cancel / Terminate the current Operation. ?
Windows is showing that LC isn't Responding, "WHEN IN FACT", It's working very hard and not Error-ing Out or Crashing.
Thanks, Chip
