Hello Guest it is November 02, 2026, 10:07:53 PM
Author Topic: confused and pissed  (Read 11767 times)
confused and pissed
« on: May 10, 2016, 05:05:04 PM »
I built a cnc router using nema 23 270oz. steppers and the tb6560 board. I can jog both x and z axis at slow speed but the y axis just vibrates. I even replaced the tb6560 with a new one and the problem is still there. All the axis will move at high speed including the y axis, but it will not jog at low speed. I've tried about every setting there is with no luck. I'm not using micro steps.
Re: confused and pissed
« Reply #1 on: May 10, 2016, 05:52:02 PM »
Try swapping the cable from the x to the y. Just one end of the cable, this will verify the y motor is good.
« Reply #2 on: May 10, 2016, 08:25:20 PM »
I've tried that, the other axis becomes the problem
Offline dude1
  •  1,253 1,253
« Reply #3 on: May 10, 2016, 09:07:13 PM »
those boards are known to be not so good, look up on cnczone all bad storys
« Reply #4 on: May 10, 2016, 09:18:10 PM »
Thanks, I'll do that. I was thinking of going with a different system anyhow.
Offline dude1
  •  1,253 1,253
« Reply #5 on: May 11, 2016, 12:38:21 AM »
good idea
« Reply #6 on: May 11, 2016, 02:58:11 AM »
Your problem will be mid-band resonance. It occurs at low speed in the range of 2-6rps. You can hear the motors growl and change pitch when it is occuring.
What you need to do is buy a decent stepper drive such as the Gecko G540 4-axis stepper system that I sell. You won't look back.
http://www.homanndesigns.com/index.php?main_page=index&manufacturers_id=5
Cheers,
Peter
Homann Designs
