Hello Guest it is November 22, 2026, 09:42:25 AM
Author Topic: Beginners help need with CNC  (Read 22732 times)
Re: Beginners help need with CNC
« Reply #10 on: May 06, 2016, 01:59:21 PM »
Soft Limits
Circle G Code
I found this particular vectric sample gcode on a forum, I haven't actually made any gcode myself in vectric although I plan to learn this weekend.
Offline Davek0974
  •  2,606 2,606
« Reply #11 on: May 06, 2016, 02:11:28 PM »
Are you zeroing the Z axis at the surface of the material?
BTW was the g-code made for the same material / cutter you are using, things can get ugly if using settings that are way off ;)
« Reply #12 on: May 06, 2016, 04:40:35 PM »
I think there is a work coordinates setup error on the user end.
I have use Vectric Aspire with a 3040 router and mach3.  no issues.
Where and how are you zeroing your WORK zero points?  Are you moving the tool over a corner and zeroing X and Y work cords.?  Z Axis zeroed with the endmill on the top of the part?  If you are trying to use the HOME position to run the G code from it will never work.
« Reply #13 on: May 07, 2016, 10:36:27 AM »
Finally was able to get it working.....here was the problem
That should not have been green. I originally followed the tutorial on soft limit setup on instructables.com and the guy there had it green. After watching the above youtube video I posted earlier again, I noticed he had it red. Thanks for everybody's help on this silly little issue.
Offline Davek0974
  •  2,606 2,606
« Reply #14 on: May 07, 2016, 10:47:09 AM »
Nice one, now the fun starts.....
