Third party software and hardware support forums. > Promote and discuss your product
MB2 Bob for ESS
(1/1)
Weerasak:
The MB2 is an Industrial environment BOB, featuring: 6 Axis Line driver; I/O that utilizes all 3 ports of the ESS; OSSD safety output; Status LEDs for all signals; Requires a single 24V power supply.
Specification and Features:
-With ESS, Ethernet connection helps controller and drives located away from PC and has more noise resistant than USB and parallel port connection.
-Run on Mach3 / Mach4 with Windows XP, Win7, Win8 both 32 and 64 bit, on both desktop and notebook computers.
-New! Utilizes All 3 ports of ESS.
-New! Motion command signal can be selected between Pulse/Sign, CW/CCW, Quadrature. Frequency can be selected from 32 KHz to 4 MHz.
-New! Differential line driver for motion signals, makes a longer wiring with more resistant to interference when comparing to TTL open end.
-New! Single 24Vdc Power supply is needed. On the board consist of  5Vdc isolate and non-isolate dc2dc converter, thus saving installation space and wiring.
-And more...
Product Link.
http://www.cncroom.com/index.php?main_page=product_info&cPath=7&products_id=209&language=en
Weerasak:
here is correct link to Ethernet smoothstepper breakout board
http://www.cncroom.com/interface-break-out-board-mach3-mach4/smooth-stepper-ess-mb2
Weerasak:
Here is the new third generation of MB series board. The MB3, it keeps the best features of its predecessors MB1 and MB2 and in addition, allows all isolated inputs be used in both NPN or PNP mode and also to operate with either 5V or 24V. In this new design, the ESS board can be directly plugged into the MB3 without using ribbon cables. This makes the ESS easier to install and reduces the distance the signals must travel. It eliminates a number of contact points, as well as inductance and resistance between the ESS and MB3 board.
* Runs on Mach3 / Mach4 with Windows XP, Win7, Win8 and Windows10 both 32 and 64 bit, on both desktop and notebook computers.
* New! “AnaSpeed2” is a 0-10V precise analog output circuit has been implemented. This small circuit island is electrically isolated from the rest of the board, but it forms itself as part of the VFD input circuit which receives PWM signal from ESS by using light. It also has onboard isolated 12V DC2DC module which able to supply 0-10V to VFD continuously.
* New! 18 Universal isolated fast inputs on port 1 and 2. They can be used as NPN and PNP inputs, also able to handle both 5V and 24V. These inputs can detect an index signal of the spinning motor at  862,200 rpm*
* New! 5 Universal isolated super-fast inputs on port 3. They can be used as NPN and PNP inputs, also able to handle both 5V and 24V. These inputs can detect an index signal of the spinning motor at  1,710,000 rpm*https://www.cncroom.com/interface-cards/ess-mb3
https://www.cncroom.com/interface-cards/mb3
https://www.youtube.com/v/pGaCyydRLCw
Navigation
[0] Message Index
Go to full version
