Hello Guest it is November 12, 2026, 01:53:21 AM
Author Topic: wizard setting incorrect default for g94  (Read 11349 times)
« on: April 15, 2016, 09:07:20 AM »
Hello All
I am using the wizards and they work well but for some reason it is always setting the
feed at g94.
I prefer g95-
how can i get the wizaed always to use g95 instead of g94?
regards
fred
Re: wizard setting incorrect default for g94
« Reply #1 on: April 15, 2016, 09:22:52 AM »
You will have to alter the script in the Wizard.
« Reply #2 on: April 17, 2016, 08:58:57 AM »
Thanks Hood- but how do I do that?
regrds
fred
« Reply #3 on: April 17, 2016, 11:31:01 AM »
Best idea is to copy the wizard just in case you make a mistake.
You will find it in C:\Mach3\TurnAddons\Turning  If you just copy that whole folder then you will be able to place it back if something goes wrong.
Ok to edit the wizard you open the wizard from Mach then if you go to operator menu then Edit Button Scripts the Post Code button will be flashing, click it and the editor will open and you will see the code. Look for G94 and change to G95 and save and close, you should now get G95 when you post code from that wizard.
« Reply #4 on: April 18, 2016, 12:01:48 PM »
Thanks Hood-
Done and understood
Is the procedure for writing wizards documented anywhere??
Is it written in VB?
Regards and out
fred
« Reply #5 on: April 18, 2016, 03:34:48 PM »
Fred, not any documents that I know of. They are written in VB or rather Cypress and there is a manual for it/Mach on the website.
