Hello Guest it is November 08, 2026, 09:38:23 AM
Author Topic: Set Override/ Feedrate to 100%, or ignore it completely during auto zeroing.  (Read 10565 times)
Hi everyone,
I've got a problem.
I activated auto tool zeroing in mach3 with a tool length sensor.
the problem now is, that even the tool zeroing macro respects the override/ feed rate. so, of course, the Z value depends on the feed rate, as the computer and mach3 need some time to react on the sensor.
As I am a fan of foolproof solutions :-) I want to tell the macro to ignore the override/ feedrate. In case of need it would be possible to include the command to reset feed rate to 100%.
is that possible?
many thanks in advance and best regards
Georg
Try:
 SetOemDRO(821,100)
Code "M49" at the beginning of your script and Code "M48" at the end should do it.
I do that with threading on the lathe as the Ethernet Smooth Stepper  doesnt ignore the feed override  in G76  and you end up with a screwed up thread.
Hi ger21 and Hood, thanks to both of you!
I used the M48 and M49 as I understand what it does and it does not change my feed rate value. works!  thanks a lot and have a nice weekend,
Georg
