Hello Guest it is November 13, 2026, 03:02:58 AM
Author Topic: Tool moving to random coordinates  (Read 21860 times)
Re: Tool moving to random coordinates
« Reply #10 on: April 17, 2016, 01:38:33 AM »
I can 100% confirm that when entering g0 then the axis and a number it moves to that location in work coordinates. So if you zero x and then enter g0x20 it moves 20mm in axis x and if you enter the same again it doesnt move at all. Is this abnormal?
  •  9,377 9,377
« Reply #11 on: April 17, 2016, 01:46:29 AM »
That is exactly as is should be when working in Absolute mode. The X axis is already at X20 so no movement is necessary.
On the other hand, if you were working in Incremental mode then the X axis would move another 20mm.
This is all explained, much better than I can, in the Mach 3 Manual. http://www.machsupport.com/help-learning/product-manuals/
« Reply #12 on: April 17, 2016, 01:59:31 AM »
Thank you I should familiarize myself with the manual properly
  •  9,377 9,377
« Reply #13 on: April 17, 2016, 02:17:19 AM »
I don't think you can expect to learn it all (there are parts I still don't fully understand) but the combination of manual and hands-on experience seems to win out in the end.  ;)
