Hello Guest it is November 19, 2026, 12:56:15 PM
Author Topic: How many use Notepad++  (Read 55790 times)
Re: How many use Notepad++
« Reply #20 on: November 13, 2016, 02:51:53 PM »
Just discovered this.  Looks excellent!
Keep up the great work!
Leo
« Reply #21 on: November 15, 2016, 10:44:27 AM »
Thanks Guys!
When you run the installer the default action after install is to open the release notes in notepad++. Its worth reading. It should help eliminate some confusion. It is not meant to be an in depth tutor for Notepad++ but the Notepad++ Cheat Sheet the installers puts on your desktop goes much deeper into using Notepad++.
« Last Edit: November 15, 2016, 10:48:25 AM by Chaoticone »
« Reply #22 on: July 28, 2017, 07:46:20 PM »
Looks great.  I'll try it out.
However, where else are all the functions and API listed and explained.  I think I read through all the Docs that came with the Mach4 hobby install and some others on the site.  All the examples certainly help and I have written some startup screen, m-code scripts etc but I'm not very efficient at it.  Where did I miss this critical info?
thanks
« Reply #23 on: July 28, 2017, 09:31:44 PM »
Once again I get to answer my own stupid question.  The info is in Mach4CoreAPI.chm which won't open on a Mac.  Opens up fine on the PC.
« Reply #24 on: July 04, 2024, 04:13:55 PM »
Hi guys, sorry to resurrect this but this doesn't appear to work with the modern versions of notepad++ any thoughts?
