Hello Guest it is November 13, 2026, 06:25:36 PM
Author Topic: PWM output...  (Read 23729 times)
Offline Davek0974
  •  2,606 2,606
Re: PWM output...
« Reply #10 on: March 28, 2016, 11:26:30 AM »
I have now measured the 0-10v signal but only by disconnecting the VFD?
Odd.
Is the a way of editing linearity.dat manually?
Does anyone know whats in it?
I have listed volts to speed requested now and also speed requested to speed obtained.
Obviously i can use a manual lookup table but thats  not the point ;)
Offline Davek0974
  •  2,606 2,606
Re: PWM output...
« Reply #11 on: April 01, 2016, 01:56:34 PM »
SUCCESS!
I changed the VFD from the Huanyang to a UK Schneider Altivar12 unit.
It measures correctly now, the motor sounds better, smoother, draws less current. Sensorless-Vector seems to be unstoppable even at 100rpm!
According to the tech guy at the suppliers, with sensorless-vector drives it is 100% vital to run an auto-tune sequence once all the parameters are set.
I also managed to calibrate the speed to Mach3 successfully :)
In the end, all it took was taking the minimum spindle pulley to -6500 and max to +24000 - I now have usable calibration from 5,000 to 24,000 rpm to within 200 rpm.
