Hello Guest it is November 13, 2026, 08:08:04 PM
Author Topic: Taper Turn Wizard - JT2 Morse taper not right  (Read 23494 times)
Re: Taper Turn Wizard - JT2 Morse taper not right
« Reply #10 on: March 20, 2016, 03:56:37 AM »
Here is a screenshot of what I entered and the last pass highlighted.
« Reply #11 on: March 20, 2016, 04:12:51 AM »
I'll check out the Wizard based on diameter and radius modes with and without a finish cut and see what the backplot
of the code tells me.
Will post the results here.
Hopefully sometime today,
« Reply #12 on: March 20, 2016, 05:30:03 AM »
Ok just ran it again but this time I looked up the specs for the Jacobs, the length is 22.352mm (0.88in)  where you had 22.23
So if I use the value of 22.352 then I can use the finish pass and any clearance and  get a very close value to what it is meant to be, see screenshots, with different clearances.
« Reply #13 on: March 21, 2016, 08:20:04 AM »
Fooled around with the OD Taper Wizard a little.
Code generated was fine if in RADIUS lathe mode, but, I got some mixed results when checking it out if in Diameter mode.
So need to do some more checking. I'll post a link to a document that will be in Members Doc's explaining it all.
Be carefull when using the wizards  as some do not work for both lathe modes. Don't remember which ones though.
« Last Edit: March 21, 2016, 08:21:50 AM by RICH »
